C-Fly DREAM oder JJRC Fly HERON X9 - GPS WIFI FPV With 2-Axis Gimbal 1080P
Sidri
Danksagung erhalten: 10 Mal
Re: C-Fly DREAM oder JJRC Fly HERON X9 - GPS WIFI FPV With 2-Axis Gimbal 1080P
15:44 ,So 16. Jun 2019,
DeWe hat geschrieben:
18:44 ,Sa 15. Jun 2019,
maybe it's hidden under the plastic cover?
If you didn't know the type of IC and the place on the PCB, than there no chance to replace them.
Under the plastic case there is a gyroscope chip and a barometer. What the chip could not read is too small
19:52 ,So 16. Jun 2019,
It could be a MPU-6050 Rev. /Vers C
Make clear picture from the chip and zoom in.
I'll believe. If you can buy the chip somewhere... Maybe as a Dof 6 Flight controller for small money , every repair station for mobile can de- and solder the chips for small money, too
Sidri
01:25 ,Mo 17. Jun 2019,
Full marking gyro such: MPU6050A JAV994LA1 1809
08:34 ,Mo 17. Jun 2019,
If you're sure, that the Gyrometer is defekt, search this chip or a cheap part which contains the chip and (let) replace this chip on your PCB.
Btw:
Are you're sure, that all contacts are already fine? On the 2nd pic, the upper flexband looks like not 100% straight in the socket....
Open the flexcable holder very gently (don't crack them - it's going faster as you think), move the cable straight and till to the end into the socket and close the holder to make the connection and fix the cable. Try if it's work
Sidri
09:11 ,Mo 17. Jun 2019,
The loop is in order, I checked the contacts directly on the boards, there is contact between the boards.
I found a GO-521 module with a MPU-6050 gyroscope. On datasheets they are similar, the other day I will try to replace and check.
There is one effect on both main boards - the gyroscope does not work.
Taking into account the fact that with the help of my firmware one drone was already restored and he didn’t have problems with the gyroscope, I conclude that the gyroscope is not working properly
09:46 ,Di 18. Jun 2019,
At which time the problem with the Gyro occurred?
Does the Gyro was working till something was happen e. g. try to read/write the FW?
With which programmer does you worked?
The background of the question is, that some CPUs have also connected Hardware on the Program Pins. Also if the CPU has no problems with 5V for reading /writing via a programmer, the connected Hardware could be die, if the voltage is higher as 3,3V. Best example is the first Multiprotocoll Board for the Taranis. The program Voltage must be 3,3V. It was hard to find a programmer which switch all voltage pins to the CPU down to 3,3V. The most of them switch only the normal voltage down, but the high level pulse is already 5V ;)
Sidri
14:35 ,Mi 19. Jun 2019,
The problem with the gyroscope arose after I killed the drone firmware. I ordered a new main board, set it and she did not immediately see the gyroscope. After I received the firmware I poured it into the first board and she also did not see the gyroscope.
Stitched the programmer ST-Link protocol SWD, and it uses 3.3V.
Today I once again tried to connect the gyroscope board to both the boards. The result is the same, the gyros do not see both boards. Only the red LED blinks quickly 6 times.
14:57 ,Mi 19. Jun 2019,
Maybe you've luck and only the Voltage-regulator is broken ?
Could you make some measurements again Ground of this part?
Which Number is written on it, which Voltage is on each pin?
Sidri
08:31 ,Do 20. Jun 2019,
Checked voltage regulator (labeled DB-500 or DE-500). At the entrance of 4.9V, at the output of 3.3V.
Today I will try to re-solder the gyro chip
11:55 ,Do 20. Jun 2019,
I'll hope you are using a hot air station
Sidri
16:20 ,So 23. Jun 2019,
Yes of course.
So nothing happened. The gyroscope still does not work
21:58 ,So 23. Jun 2019,
Could you check, if you received the clock and the MPU-6050 send Datas to the mainboard?
As externel sensor the barometer is connected (from what I've seen on your picture. Does the Barometer received a clock and send Data back to the MPU-6050 (Pin 7/8)
Datasheet : https://store.invensense.com/datasheets ... V3%204.pdf
Btw: you've wrote in history:
I restored the first board, the Mission Planner sees it, and uploads the factory configuration file
If the assignment of the Gyro is wrong (maybe from the MissionPlanner) e.g. wrong Port, Baudrate .... you'll never received any valid datas from the Sensor...
Maybe there is someone available to compare the different settings....
Pasqui55
Kopter & Zubehör: Hubsan Zino
JJRC X9 , Mjx Bugs 2c
Dji F450 radio Aurora 9
2 Parrot Bebop 1(venduto)
Parrot Disco FPV(venduto)
Phantom 3 STD (venduto).
Horizon Qx350(venduto)
Syma X8(venduto)
Zerotech Dobby (venduto)
Hat sich bedankt: 6 Mal
Danksagung erhalten: 5 Mal
15:38 ,Mo 24. Jun 2019,
@Sidri
please send me the you Firmware for test on my old X9 with mainboard 2.1 rev.... very very thank you if repair my
x9 stuck da 5 mesi...👋🙂
Grüße Pasqui
Sidri
06:08 ,Mo 1. Jul 2019,
Firmware link:
You need to flash the programmer ST-Link or J-LInk to the protocol SWD. If you need later I can make instructions with photos
Folgende Benutzer bedankten sich beim Autor Sidri für den Beitrag (Insgesamt 2):
Wolle Can Fly (09:18 ,Mo 1. Jul 2019,) • Pasqui55 (14:55 ,Do 3. Okt 2019,)
Bewertung: 11%
Floyd0815
Kopter & Zubehör: JJRC X9
10:28 ,Di 2. Jul 2019,
Sidri hat geschrieben:
You definetly need the programmer to pull the firmware from the SOC, but do you really need it to flash it back on?
Because the problem in the first place was that the GC software flashed the wrong fw so it should be possible to do it through the sw.
Or did you try it and it didn't work?
mario72
Kopter & Zubehör: DJI Tello
C-Fly Dream
Bebop 1
17:53 ,Fr 5. Jul 2019,
ich bin der neue hier ;)
Ich bin seit heute morgen Besitzer einer C-Fly, und hätte da mal ein paar Fragen...
Ist die Video Qualität auf einer SD Karte besser als die auf dem Handy aufgenommenen Videos? Denn irgendwie sehen die Videos von der Qualität nicht so aus wie diverse andere auf YouTube. Ich hab zwar keine Qualität wie die einer dji erwartet, aber so sieht es doch eher wie die schlechten Handy Videos von früher aus.
Von 3 Testflügen hatte ich nur einmal auf Anhieb genug Satelliten zu Verfügung. Beim letzten Flug kamen während des fliegens weitere hinzu, so dass ich dann per GPS fliegen konnte.
Beim 2ten Flug war nur ohne GPS fliegen möglich. Dazu hatte ich dann aber eine Flugzeit von knapp 20min. GPS verschlingt wohl viel Stromspeicher ;)
Der Gimbal lässt sich nur sehr schnell auf und abwärts bewegen, kann man das irgendwo einstellen/korrigieren?
Die Joysticks der Funke haben sehr viel Spiel, genaues und langsameres navigieren ist so nur bedingt möglich... Kennt da jemand Tricks???
Leider konnte ich Waypoints nicht nutzen da das Google Ding nichts anzeigt. Wie funktioniert das denn???
Viele Grüsse
Mario
19:01 ,Fr 5. Jul 2019,
Hallo Mario
und willkommen hier !
Mir dauert der Download vom Dream zum Handy zulange, deshalb nur mit SD am PC ;) Viseoqualität ist nur befriedigend, Fotos sind ok.
Gelegent lich starte ich trotz wolkenfrei mit nur 8 Sats, in der Höhe kommen meist noch 4-6 dazu, was ausreicht um die Position halbmetergenau einzuhalten. Das mit 20 Min Flugzeit ist verwunderlich, müsste ja im AltHold nachvollziehbar sein. kaum zu glauben ;)
leider nicht, musst feinstfühlig antippen :)
Eventuell mit Parameteranpassung im MissionPlaner (ARDUPILOT)
Habe noch die 1. Version der Funke, die geht feinfühliger.
! KEIN FirmwareUpdate ! Durchführen
Leider machen verschiedene Smartphones Probleme mit den mobilen Daten/Internet wenn W-Lan verbunden ist.
Dafür erst C-Fly App im "INTERFACE VIEW" starten ohne WL-Verbindung und da die Karte öffnen und auf Wunschflugfläche zoomen. Dann erst den Controller per WL verbinden und die Dream einschalten. Die Kartenansicht bleibt erhalten und die APP findet die Dream.
Pasqui55
Syma X8(venduto)
13:43 ,Do 11. Jul 2019,
Firmware link:
Grazie appena posso ci provo....
Grüße Pasqui
Twinente
Danksagung erhalten: 3 Mal
17:24 ,Do 11. Jul 2019,
Hallo Mario
das Kartenproblem habe ich gelöst,indem ich die
Karten Offline geladen habe.
Twinente
17:33 ,Do 11. Jul 2019,
Noch eine Frage an unser Spezialisten !
Ich vermisse bei meiner C Fly Software
den Button Gyro Caly.den die JJRC hat.
Ist es möglich mit der JJRC Software
die C fly zu betreiben ? Hat das schon
jemand versucht ?
17:56 ,Do 11. Jul 2019,
Hallo Twinente !
Die C-Fly lässt sich komplett mit der JJRC-App fliegen und umgekehrt :)
Wenn der Kopter sauber schwebt ist die Gyro Kalibrierung nicht nötig, kann aber wohl
auch im MissionPlanner (Ardupilot) durchgeführt werden. !!!! immer die Parameter mit
eindeutigem Namen speichern bevor Änderungen im MP durchführst.
Twinente
17:52 ,Sa 13. Jul 2019,
C-Fly Dream abgestürzt!
Trottle Stick Links Mode 2 , ganz nach unten gedrück .
Im GPS Mode ergibt ,Motoren aus.
Ärgerlich wen der Dream 75 Meter hoch ist.
Schön wäre hier eine funktion wie zb.Min Trottle.
Läst sich im ArduPilot sicher realiesieren.
Aber wo und wie.
Twinente
17:58 ,Sa 13. Jul 2019,
Wie kann man sich hier für gute und Hlfreiche Beiträge bedanken ?
23:40 ,Sa 13. Jul 2019,
mit Daumen hoch, wenn mit Maus über Beitrag
23:48 ,Sa 13. Jul 2019,
Seltsam, kann ich so nicht nachvollziehen, da ich NIE Throttle auf länger auf Null ziehe.
Egal welcher Flugmode aktiv ist, wenn Gas länger auf minimal dann gehts schnell nach unten,
je nach Mode reagiert der Kopter auf Knüppelweg weniger empfindlich.
Werde das bald mal in Bodennähe testen.
Insgesamt sind 237 Besucher online :: 3 sichtbare Mitglieder, 0 unsichtbare Mitglieder und 234 Gäste
Mitglieder: Bing [Bot], Google [Bot], Semrush [Bot]
Beiträge insgesamt 86913
Themen insgesamt 6173
Mitglieder insgesamt 4331
